Couldn't help myself today, so I pulled the boat out and ran it on the ear muffs. The motor started up immediately so I ran it at idle speed for a few minutes. everything great.. Shut it down and decided to add SeaFoam to the gas just to try it out and do a little carb treatment. After adding the seafoam, started it back up. Ran fine for a few minutes and then started going from 800rpm to around 1000-1100, back and forth. Eventually it stalled! Couldn't get it to start again.. I pulled the plugs, they didn't look very fouled but were wet with some black oil, not sludge but thin oil. Cleaned them and tried to restart, finally got it running but it is really struggling to stay that way. It sounds different also, it won't hold idle and it really sounds like it's starving for fuel. I have to advance the throttle to fast idle just to keep it running (sometimes it stalls anyway) and it doesn't have the punch out of the exhaust like normal. <br />Anyway, I strongly suspect the seafoam is the cause. Will adding seafoam to gas that was previously treated with stabil cause problems? If so I may have caused more harm than good. <br />Any suggestions appreciated...<br />Do I need to get on the lake and open it up to flush it? Or do you think I now have a fuel problem?<br />Motor listed below....
