Re: merc 200 20hp water pump
The impeller is not that hard to do, but you should get a manual, especially if you are new to outboards. Might try your local library if you don't want to buy one. <br /><br />But if the pee hole is plugged, a new impellor won't make it pee. Find and clear the hole first, then you can see if it pees. Once you know it is moving water, you can check other systems, see what other parts you need, and order them all at once--or at least that is what I'd do. Also change the lower unit oil and see if it is milky or looks like the color of peanut butter, or has water in it. This will tell you if you need to replace the lower unit seals. You will want to do that while you have the lower unit off.<br /><br />Impeller is about $15. If there is no water at all coming out, it may be the impeller or it may be that someone dropped the lower unit and didn't get the water tube aligned when they put it back together. But I'm betting on bugs in the pee hole.
