Hello all,
I recently swapped a Mercruiser 3.0 (0F267543) from a '95 Bayliner 1952 cuddy into a 2001 Searay 180 (Transom 0L515514). I seem to have an alignment issue that I'm not very comfortable with. I installed the engine using the original hardware and checked the coupler alignment with an alignment tool. The initial alignment was a decent amount off and required the front to be lowered. After dropping the front to the lowest point, I am still only getting about 75-80% spline grease transfer around the alignment tool. I am checking this alignment using the old original gimbal bearing and planned to get a preliminary alignment set before replacing the gimbal. I tapped the alignment tool in 90 degree increments to help center as recommended but still get the same results. Does anyone have any idea why this would be giving me an issue? I'm assuming that Searay and Bayliner have their differences in how high the forward mount is designed into the hull but not so different as to require shimming in the rear? I'm reading/hearing that shimming should never be required. Help!
Jason
Jason
