SimpleM
- Apr 19, 2008
- 24
1987 3.0 Alpha 1, purchased mid April with 172 hours on it. I have always had to give it a little throttle to get it to start whether hot or cold, and it will only idle out of gear for about 60-90 seconds before it seems to load up, run rough and die. However it will putt along in gear at idle without dying most of the time. (could slight mis-alignment of the shift interrupter and engine vibration cause this problem in out of gear situations?)
My initial problem (about 3 hours after test drive and purchase) was with the engine not reaching WOT, which then progressed to stumbling and not running with any power above low rpm at all. Trim pump operation pulled down rpms badly as well. I discovered I had a loose distributor cap and when I tightened it the boat ran fine. (however needing throttle to crank and the out of gear idle issues were still present)
Fast forward 2 weeks and 12 additional hours on the meter; the boat is beginning to stumble at higher rpm and under acceleration, as well as a couple of backfires. Also, when I operate the trim motor it is dropping the rpms again. Assuming it is a loose distributor cap again, I tighten it, but actually it was already very tight. So, I take the distributor cap off and inspect; everything looks reasonable. Points plate screws will tighten about 1/2 a turn. I then spray some WD-40 in the cap for possible moisture and re-attach. Crank the engine and it runs like crap, worse than before... I figure it is the WD -40 just burning off and give it a minute @ 1500 rpm. Still runs like crap. So I check firing order; correct. I re-remove the distributor, and discover the metal arm on the rotor is broken off and laying on top of the points plate. A-ha... Likely the culprit. I checked the bottom of the rotor, and the key notch was chewed up completely. This could explain the gradual worsening of performance at WOT and under acceleration. So... I go out and buy a new rotor. (On Memorial Day Monday... thank heavens it is a well populated area) I figure that I might as well do the dist. cap and plugs at the same time. Armed with a cap, rotor and plugs I return to work on the boat. I only do the cap and rotor to start with. (Old car habit, change one thing at a time to isolate cause... guess it applies in boats too.) When I test drive it stumbles a bit at first, but as I run it about 1/2 a mile it smooths out quite a bit. I am disappointed the cap and rotor did not fix it completely, so I decide to change the plugs. Old plug inspection reveals 2 perfect plugs out of #1 and #2, but #3 and #4 are significantly dry black. Assuming the plugs were affected because of the slowly disintegrating rotor, I put the new set in. (however why just 3&4 if it was rotor?) Crank, (still having to give some throttle, still wanting to die our of gear) idle out of slip, hit it, and WOW. Smooth as silk, great power, smooth acceleration, trim pump not affecting the rpms at all.
I wish this was where the story ended with the standard happily ever after, but alas, after about 3 hours of playing with the kids tubing and kneeboarding the stumbles and trim pump rpm pull-down returned. I ran it up to WOT just before I parked it and it did smooth out quite a bit, but not to the point it was right after the rotor, cap and plug change. It was twilight when I parked it so I did not pull the plugs to inspect, but I bet I will find #3&4 will be black. Where do I start? Coil? (tach has jumped a bit and never been consistently accurate at higher rpms) Timing? Points? Condenser? Carb? Fuel/water sep.? Carb filter? Last compression check was fairly solid and all cylinders within a few psi of each other so I feel this is ignition or carb related. I would like to get this problem fixed so I can tackle the idle/cranking issue. I guess they could be related if it is a carb issue.
Help. Please...
Help. Please...
