3.0LX / Alpha One will not reach WOT RPM of 4500-4800. Only about 3000.
Compression readings on all 4 cyilnders are within 2psi of each other, however, they all read approximately 100psi... right at the minimum listed in the Merc manual. Is this compression bad enough to be causing 1500 lost rpms at WOT or have I additional problems? I've checked for exhaust obstructions and gone over the ignition and prop issues. All that seems to be left is the carb / compression.
