Re: Merc 302 vs 351
I used most of F_in's advice. I rebuilt my 302 as follows:<br /><br />Bored 30 over, new valves, cleaned the ports in the heads<br />Hastings Molly Rings<br />Speed Pro Flat Top Hypertectic Pistons<br />Crane Energizer Cam kit including lifters and springs, Grind# 266 H10, .469 lift and 210deg duration, changed to 302 firing order<br />Clevite 77 bearings<br />Melling High Volume oil pump (mistake, use standard volume)<br />Cloyes Tru-roller double steel timing set<br />Pertronix Ignitor 2 ignition upgrade, matching Flamethrower coil, new 8mm Magstar Marine wires<br />Topped off with the original 2bbl Rochester carb (rebuilt).<br /><br />Original HP: 188, New HP: ???<br />Original top speed: 40-42 speedo New top speed: 47.8 GPS before carb rebuild and more tuning.<br /><br />Well pleased with my 302. Although som may comment on the auto cam, I have more than enough grunt for some brutal holeshots and wot is right where it should be. I can't just nail it to pull a skier up, I have to ease into the throttle a bit or I pull them up too fast. I thought about the 351, but the economics weren't there and the extra height/width probably wouldn't fit well in my engine bay.<br /><br />To answer a previous question, the rings on the manifolds are lifting rings for the engine. There is a 3rd one behind the carb on the intake manifold.<br /><br />If you are buying new manifolds and risers, consider going with the center risers if you can get a conversion kit. I wanted them, but the conversion scared me at the time. The stck logs work fine and make handling the engine a bit easier with the rings, but I'm told the centers flow better. There is a company that makes stainless exhaust for the 302 and 351 that is about $1400 shipped from Australia if you are interested. They weigh a fraction of what the cast ones do. I can dig up the info if you want it. If I had the cash....<br /><br />For my 19'er, we get about 3.5mpg at a 3200rpm cruise at about 30-34 mph. with 2 people. 4 people doesn't affect milege much.<br /><br />Northerautoparts.com and ebasicpower.com got lots of my money when I went through this......<br /><br />BTW, be sure to go ahead and replace the exhaust flaps in the bases of the Y pipes while the engine is out. They are probably gone if it inhaled water. Cheap PM.
