Merc 350 Mag Alpha 1 couple of questions/concerns
tarheelebbtide
1992 Mercruiser 350 Mag 5.7L recently rebuilt (last year) with all new peripherals (water pump, weber 4bbl carb, starter), and Alpha One sterndrive. It has thru hull stainless exhaust with the y-pipe for the below water exhaust capped off in the engine compartment. Let me first say that I'm probably overly paranoid about the boat since the rebuild so both of these may be nothing.
Yesterday when out for about 4 hours, I kept thinking I noticed the slight smell of gasoline a good bit of the time. Of course this is a carbeurated engine so I'm not sure if it is running rich and exhausting unburned fuel or if it's natural (particularly with the above water exhaust) to smell just a bit of fuel (and it isn't much of an odor at all). The second concern is that if at idle through a no wake zone for a long period of time, the boat will run warm (about 175 on the guage). If i notch it up to a fast idle, it comes right back down within 15-20 secs and hovers at the correct 150. It also holds 150 consistently when out on the open water. It will have a small and brief spike if I run it hard (4000 RPM or better) and come back down to a fast idle, but I assume that's natural as it quickly rectifies itself. The impeller is less than a year old as is the engine recirculation pump. It's almost as if the impeller doesn't spin fast enough at idle to circulate a good water flow but at just above idle it's fine. Could this be a symptom of the rebuild and boring (as in the engine naturally running warmer due to larger pistons and thinner water jacket)? Anyhow, I might just be paranoid about both issues as it ran like a champ all day and will blow just about anyone nearby out of the water, but I'd rather be safe than sorry.
Just FYI, it's only used in fresh water.
Don S
Re: Merc 350 Mag Alpha 1 couple of questions/concerns
How old is the impeller in the outdrive?
derekpfeiffer
I believe he had said the impeller is less than one year old. Everything sounds fine to me. I've got an 08 w/ the 5.7 mag in it and it always runs straight up at 175 deg. I really think you have nothing to worry about...but I can relate paranoia can be a terrible thing:)
Good luck and happy boating,
Doogie
tarheelebbtide
Don, the above poster is correct...the impeller is less than a year old. I replaced it in September of last year. I think I'm most likely just being paranoid, but I think if you boat long enough, you get to that point!
Mkos1980
Should never get over 150ish with the correct 140 stat.
Don S
Actually, it's quite normal to run in the 170? to 175? range with a 140? stat when under a load.
When the impeller was replaced, did new gaskets get installed on the pump housing? Or were they installed incorrectly. Old gaskets can leak, and new gaskets can be put on wrong and it will just slightly miss the edge of the housing. This would really reduce the flow at idle speed, but be made up for at higher rpm.
tarheelebbtide
I put new ones on, but it's certainly possible that I didn't get them on perfectly as it was the first attempt at taking a wrench to my boat. I'm fairly mechanically inclined, just a first timer when it comes to boats. Don, do you think it's something worth worrying about right now, or just finish out this season with it, and correct it over the winter?
Don S
I may have a crystal ball in my avitar, but that doesn't mean it works.
Ayuh,....
How about the T-Stat Housing,..??
I chased a mysterious Overheat Spike for Years,...
Before I figured out I was running a Gen.II housing with a Alpha 1 drive....
Without the Check-balls, it would spike to 200? while trolling...
Put the Check-balls in,+ problem Cured.....
Btw,...
In My experince,.. Those Webers are All jetted too Rich,...
Fatter Needles cure the Smell with mine....
tarheelebbtide
Bondo, thanks for the reply on the t stat housing and carb. How would I go about checking the housing to see if it's the correct one? Also, have never worked on a carb before...can you explain what you mean by fatter needles? I appreciate the help. I'll post pics and follow ups if necessary!
