crwallaceva
- Feb 7, 2004
- 7
I have a 1990 Merc 350 magnum. I started winterizing last night. I have the DIY boat winterizer that is a 5 gallon jug with a "T" for both fresh water and antifreeze. Everything runs fine with fresh water and temp stays about 1/2 way on the temp guage. Once I cut the water flow and start the antifreeze flow, the engine warms up tremendously. <br /><br />Should I just pump antifreeze on cold start or should I pump fresh water until thermostat opens. <br /><br />I'm changing thermostat just in case. I did test it and it was functioning properly - obviously since the fresh water was keep temp at normal range.<br /><br />I'm also using -50 degree RV antifreeze which is recomended by Merc manual.
