Merc 35hp with oil pump.
xxlurchxx
Got a 35 hp Mercury with an oil pump that mixes the oil with the gas in proper ratios I assume. Can I remove the oil pump and just mix the oil and gas or should I try to find a replacement oil pump? I have not been able to locate a pump on this site, if I should replace the pump could someone point me in the right direction. Thanks
Faztbullet
Re: Merc 35hp with oil pump.
That is the old Autoblend unit, disconnect it and go to premix as they are NLA and no updates for them.
xxlurchxx
Ok since I am a total newb, what is the proper ratio of oil to gasoline for a 35HP motor?
Faztbullet
1 pint of oil per 6 gallons of fuel.
