Merc 4.3 not starting
Oduwake25
so at the end of last summer I dropped a nut into the carb and down into the intake. So we started pulling it apart we took off the heads and everything before that.( including rebuilding the starter) So I just recently put it all back together and when i go to start it it just turns and turns. I got it to run with WOT but it ran rough. Now over the winter i was not able to run stabilizer through the carb. IDEAS? do you need more info?
