I have a '96 Mercruiser 4.3LX with an Alpha 1 Gen 2 drive unit, the original power package in my '96 Larson 174SEi. The boat and motor have probably less than 250 hours (it didn't come with an hour meter). The lower unit makes a knocking noise when turned hard over in either direction and the trim is down. It has done this since I bought it new, but very mildly. I had to turn the wheel all the way to the stops for it to happen, and thought it was normal. I just avoided forcing the wheel all the way over. Last summer the noise became more pronounced. Specifically, I didn't have to turn the wheel as far over before the knocking began, nor did it have to be trimmed quite as far down. I took it to a Mercruiser authorized shop where they replaced the gimbal bearing and U-joints. Next time I used the boat, the noise was LOUDER. If the lower unit is trimmed down more than halfway in its normal range and the wheel is turned more than halfway to either direction, the knocking begins, and gets progressively worse the lower the trim and more hard the turn. It used to be that it only occured during idle speeds, because that was the only time I turned the helm that far, but now it happens during normal maneuvering at speed.<br /><br />They pulled the lower unit again, and it looked like the aft yoke on the U-joint assembly had been coming into contact with one of the tabs, or "dogs," of the retainer nut on the upper gearbox. They tried to grind down the dogs a bit, but to no avail. I don't dispute the need for the new gimbal bearing and U-joints - they needed replacement - but they clearly didn't fix the problem, and the technicians are scratching their heads. The alignment was perfect; in fact, they said the alignment bar went in more easily than many new boats. After months of waiting, a Mercruiser tech support person finally called the shop. His only suggestion was that the transom was weakened, causing the unit to travel farther down than it should. I think this is extremely unlikely. I don't think it is rotted because the boat has always been trailered (never spent a night on the water) and I've seen no evidence of any leakage or other condition that would allow water damage. I have also seen no evidence of any kind of collision damage that might result in a weakened transom.<br /><br />The techs all say they've never encountered this. Ordinarily, noises such as this occur when the lower unit is trimmed UP, causing more binding in the driveline. The conventional wisdom is that the noise should abate then the unit is lowered and the driveline is at its straightest.<br /><br />Sorry for the long post.<br /><br />Any suggestions?
