Merc 400
55 Cruizon
I Have a 1960 Merc 400E (serial# 1284884). I use it mostly in salt water. I need to clean and re-grease the swivel pin. I,m having trouble removing the drive shaft housing assembly. I followed my original manual, removing upper and lower mounting nuts. The lower mount screws are completely loose. Are there any suggestions for loosening/removing the top screws? Do I need to remove the upper covers? The four srews holding each upper mount cover are difficult to loosen.<br />Thank you,<br /><br />David
