Merc 402 Lower Unit Won't Come Off
phinfan
I have a middle to late 70's Mercury 402. For some reason the lower unit won't come off. I have the service manual and have done every thing correctly, it drops down about 1/2" but something is still hanging up. Can anyone help PLEASE???? <br />--------------------------------------------------------------------------------
Yepblaze
Re: Merc 402 Lower Unit Won't Come Off
Unscrew the hidden bolt. Either in the hole as viewed towards the rear tip from above. Or sometimes under a trim tab as viewed from below.
JackLo
Had the same issue last spring with my 402 I bet you it is seized up top near the motor.
if you can turn it upside down and spray a lot of pen oil up towards the motor along the drive shaft let it soak
I had to beat on the bottom fin forwards and back (did a bit of damage) to get it to release
check out utube videos for a few tips
