a friend has a 1999/98 454 magnum fuel injected motor,just had the head reconed,now he has refitted them,and found that the engine keeps stalling when throttle is put to idle position,if he keeps it just of idle it is ok,i was thinking it was the idle passage in the throttle body blocked,or air leak at inlet manifold,thinking a vacuum gauge may pick up a leak, also when at operating temp it is hard to start,have to hold full throttle and crank for a while to fire up,any help would be great,thanks john from new zealand.
