njdvlsfandan
- Sep 26, 2004
- 2
I recently purchased a celebrity with a 454 merc engine with 264 hours. The boat had one owner who did not use the boat much. I took the boat out for about 3 hours and it ran great with no problems. I took it out this weekend and put in some new gas and it ran great for about an hour then the boat started to sputter and backfire and eventually would stall if you went above idle speed. I replaced the water seperator filter and put some dry gas in the tank, I sprayed some gum out in the carb and took it out again. She ran great for about 20 minutes and then began to sputter and backfire and stall. It seems that the boat ran better after it sat for about a half hour but then it goes back into the same routine. Any suggestions before bringing it into the shop would be greatly appreciated.<br />Dan
