merc 454's
rodbolt
I know a marina that is doing a repower. I took a pair of 454's out. one is counter rotating, compression is decent motors have about 2000 hours. they are complete with clutches. I think the clutches are 72 seriers velvet drives with a 1.98 ratio. motors can be had for a decent price. I think the guy is asking 5K for the pair.may golower. I did see ATF in the bilge so I suspect at least one of the cluches may leak or when he replaced the port trans oil cooler the fitting is not tight.I think they are 1990 motors.<br /> but they are full fresh water cooled and the risers were replaced a few years back and still look ok from the outside.
rabidfish
Re: merc 454's
Wanna mount them in the bed of my pick-up truck and see how much noise we can make?<br /><br />I'll bring a couple bottles and we'll make a weekend out of it... Everybody loves... you gessed it! TWINS!!
rodbolt
Re: merc 454's
hahahaah<br /> I can fire them upon the trailer.<br /> they are complete so all you need is a battery two cables and water and 2 jumper leads and they will purr. but I have no use for them monsters. I cant afford to feed my 120 jonnyrude. I just thought I would tell the board about a set of decent engines in case some one has spring fever :) now installing the new 8.1's with the down angle ZF trannys is gonna be fun. the block to coupler flange is 6" shorter on the new ones so I have to replace all the mount pads and move them aft 6" and that will start the project.<br /> gosh I hate big boats but the 25 hours or s pay is nice :)
