thenthfce1978
- May 22, 2003
- 2
I have a 78 Merc 470 4 cyl 165hp I/O engine that after 30 or 40 minutes of cruising cuts out like it has ran out of fuel. I can start the engine again but only idle for a bit before it cuts out again. Although tank is half full. I have replaced the fuel pump, line, and fuel sender. Cleaned all the filters. Also the cooling system has a new water pump and heat exchanger. Carb has a new rebuild kit. Can anyone point me in the right direction or tell me what could be the cause of this?
