billywhizz
- Nov 22, 2007
- 174
Rochester 2bbl carb, where does all the petrol go? accepted it cant syphon back out, so does it really all evapourate? starts fine if left for a few days but after 2 weeks have to crank for ages to get the fuel back up, tested the pump at 7psi ok? also hard to start when hot, so if the leak is from within the float bowl where do i look?
Lets go back to the explantion.
4. The only possible reason for the carb to not have fuel in it after 2 weeks, is because of a leak from the bowl of the carb.
OK Don, Quite happy to take your word for it and just about grasped the theory, my engine does exactly the same, so where should i be looking for the leak from within the bowl?
