h2oboarder
- Jun 16, 2005
- 3
Engine starts with key in start position and then dies when it moves to run. Engine runs stays running if you hotwire starter posts (purple-yellow) with main or if you run bypass directly into purple-yellow terminal. <br /><br />What is causing the engine to die without hotwiring the solenoid?<br /><br />The Merc is a 5.0 litre serial M030334, model#4m12025n1 standard rotation year 2000 motor. It is in a inboard skiboat. There is no lanyard stop that I know of.<br /><br />The boat runs fine when you jumper the purple-yellow wire with the main starter post. Fuel pump continues to run. Thought it was the ignition switch - but same problem after replacement. Tried replacing the starter solenoid but problem still exists. <br /><br />I read something about the ECM cutting out if the battery is bad/low or if the voltage regulator is bad. ???
