I have a 1990 Merc 5.0LX which started stopping occasionally while under throttle, it would restart after a minute or so. It stopped the last time and would not restart. It will not fire even with starting fluid.Acellerator pump pumps fuel. I have been thru the Thunderbolt IV trouble shooting chart. Replaced coil as it's resistance measurement was just at the edge of acceptable range, no luck. One of the tests had me strike one of the distributor sensor wires to ground and look for spark, there was a weak spark so I replaced the distrbutor pickup still very weak spark in plug on top of engine (probably not enough to fire under compression) I am considering the ignition module but they are pricy and the trouble shooting chart says it should be ok. Any ideas?
