Hello everyone,
Im having a idleing issue with my boat. I have recently re-powered with a 5.7 vortec reman from atk. The issue I’m having is when the boat is cold it starts and idles for maybe 5 mins. Once warm it will run rough and stall. I turn the key off then back on, crank the motor, starts and idles for 10 seconds, then dies.
Things I have checked / replaced with the re-power and diagnosing:
-New distributer
-New plugs
-New wires
-Went through carb Edelbrock 1409
-Metering rods
-Jets
-Orange springs
-float needles & seats are new
-Filters on seats
-Verify electric choke is working properly
-new floats set correctly triple checked
-New fuel pump
-New Sierra in-line filter
-Bypassed the oil pressure switch that controls power to fuel pump
-carb bowl has gas in it
-accelerator pump set on middle hole and get two full squirts on fuel when pumping the throttle so has fuel
-Assuming I have 12v to the purple wire on the ignition coil because it fires up and idles for a little bit.
-Triple checked the timing, set to 8btdc, no vacuum advance.
-fresh gas
-fuel pickup and check valve working properly
Im wondering if the ignition coil is on the way out and quits when it’s warm. I have replaced essentially everything that it could possibly be. When it dies and I give it a little throttle it makes no difference. Just abruptly stalls. Seems like everything points to coil but I have spent so much money on this boat I don’t want to just bust out the wallet and throw more money away.
any help would be great
-New distributer
-New plugs
-New wires
-Metering rods
-Jets
-Orange springs
-Filters on seats
-New fuel pump
-fresh gas
