Re: Merc 50 has no Nuetral or Reverse
Yes you screwed up when you put the lower unit back on.<br /><br />Your manual should give you more specific details.<br /><br />Manuals are available somewhere at this site. Some say right at the bottom of this page somewhere is the link.<br /><br />I'd take the time to explain it to you if I had the manual for your motor. But I don't.<br /><br />Perhaps if you made sure the shifter was in neutral then rotated the shift shaft in the lower unit<br /><br /> (again not sure about your particular motor) <br /><br />till it was in the nuetral position between forward and reverse <br /><br />(but might only appear to turn in one direction)<br /><br />so it might take a bit of trial and error,,,,,,,,,<br /><br />Then get the lower unit to engage the shift shaft while the water tubes enter the correct socketed area, and the driveshaft in the cranksahft without disturbing the shifter you just had set in the right position,<br /><br />It might work.<br /><br />But then again, I don't have the manual for your particular model nor the experience from working on that model.
