I have a merc outboard s.n. 06486332 that turns over fine but no spark
like to know were the neutral sw. is located
is it on motor near linkage or on controls
thanks
that does away with one idea I had
I found broken wire from trigger coil
to switch box , wirring out of trigger
looked brittle
do you think trigger is bad
If you found one crumbling wire, check all the wires. Fix them and then follow the CDI test Laddies posted. Those harnesses start to fall apart after a while.
