Hi,
I am having trouble to get a 1984ish Mercury 500 started. Here is what i found:
-Spark on all cylinders
-Don't have the number, but compression is okay
-Engine fired up when I dumped premix straight in the cylinder
Now to me that suggests a carb problem. So I cleaned the carbs thoroughly twice, removing some TINY gas deposits.
Still nothing. Not even a pop or something. Spark plugs are completely dry.
I cleaned all the visible jets, float chamber etc. with a whole can of carb cleaner and a needle.
The only thing that might be a problem is that I didn't take the welch plug off. Do I have to drill it out in order to clean out the idle circuit?
Are there any other typical problems these engines have that I should have a look for? Any other ideas regarding not getting gas to the cylinders?
I would really like to have everything figured out before putting it back together again, the way this motor is crammed just sucks. LOL
Appreciate your help!
