Hello! I have a 14' aluminum mirrocraft runabout (flat bottom soft keel style I think) with a mercury 650 on it. The boat is really light and small, but i want it to pull two skiers and go fast as possible. last year I upgraded from a 35 hp sea king and it still doesn't go as fast as I want. I got the merc for $225, so i have some room in the budget for a prop
It would step right up on plane and hit top speed right away (like 3 seconds) but run out of legs. just me in the boat it was about 35 mph, four people in the boat was about 32, and with two people in the boat while pulling two on skis behind was like 28-30 mph. It was pulling two skiers pretty easily. I want high top speed with one or two people in the boat, but still want to be able to pull two skiers when I want. Current prop is 10.75 x 12, how much could the pitch go up without loosing the ability too pull two skiers? I saw the steepest prop available was 10 x 17. I was thinking that I could get that one and if it has trouble pulling people, i could put the current one back on for skiing, but that would be a bit of a pain in the a. Thanks if you could help! (Its a shame to waste a speedo that goes to 50 when the needle stops at 35!) Also, the transom is 20 inches with a cutout down to 15 inches for the original short shaft motor. The merc 650 is a 20 inch long shaft so it has a lot of drag there and scoops water into the boat a bit. I'm fixing that with a strait across (no cutout) transom board as well.
