Merc 7.4l 454 Gen 4 to 5 interchangeable?
thormx11
I recently purchased a 1997 Maxum with a bad 7.4l/bravo 3. I am exploring my options for repower and came across what looks to be a good deal on a rebuilt gen 5 long block. I believe my current engine in the boat is a 1988-1991 gen 4 (serial # C602211)
I am already planning on needing to replace the exhaust, intake, carb, and oil pan as I know these are probably bad as well on my current engine. Will the accessories (alternator, P/S pump, etc) swap over to the gen 5 or would I need to change all the accessories as well?
tpenfield
That serial number comes up as a 1989 7.4L/Bravo . It is interesting that a 1997 boat would have an older engine. I assume it has been repowered previously with a used engine.
The Mark IV 7.4L will have the stamped steel valve covers whereas the Gen 5/6 will have the cast valve covers. I'm not sure if the bolt patterns will be different. I think the intake manifold is different, so I'm wondering if the Gen 5 long block will come with the intake manifold :unsure: . The Gen 5 won't have a mechanical fuel pump, so you will need to go electric or the fuel pump that is driven off of the sea water pump (think $$$$)
@Scott Danforth probably knows more of the specific differences . . . some are internal to the engine and won't really matter. Your concern would be bringing the external parts over from the Mark IV engine.
thormx11
I was planning on needing to replace the exhaust, intake, and oil pan anyway so I could buy those for the gen V. Also the boat already has an electric fuel pump with a block off plate over the mechanical fuel pump hole on the engine.
matt167
Keep in mind, if your exhaust risers/ other parts are still good, then you could very easy grab a TBI 454 out of a wrecking yard and swap over parts. It's the same engine, and all you have to do is add a marine cam, brass core plugs and head gaskets... Chevy 2500 and 3500 trucks and vans are where to look. If it's TBI it should be Mark IV.
There are a handful of differences to the Gen 5 engine
all Chevrolet motors have the same bolt pattern for the flywheel housing.
post the engine casting number (behind the starboard cylinder head, on top of the flywheel housing boss)
thormx11
I will check it tomorrow when I get to the shop. yesterday I took a quick look for numbers (mostly just the serial number) and grabbed a picture of a number where you are describing but it is on the port side. It is hard to read but I believe it is 615445. I will look at the otherside tomorrow for numbers.
Casting number will start with 101xxxxxx or 125xxxxxx
the casting numbers are always in the once spot - behind the starboard side head deck, on top of the flywheel housing embossment. the engine serial number from GM is on the port side (not needed).
thormx11
I looked this morning and did not see a number like you described. I think there was a smaller 3-4 digit number starting with the letter M. I am heading back to put the engine on a stand and take a better look.
thormx11
According to that link it looks like the casting number should be on the port (drivers side of vehicle.) That is the first number I came up with, the only number in that location on the starboard side is M258. The closest number I could match up to the number on the port side of my block is "14015445...454.......78-90...2 or 4 bolt"
I believe there is quite a bit of flaking paint/rust covering up some, I may have to take a wire wheel to the numbers and try to come up with more.
thormx11
I found a decent deal on a rebuilt gen 4 (about $2500 shipped) but after the core charge it wouldn't be such a good deal. I would assume with an internally cracked block they wouldn't accept it as a good core.
The gen 5 longblock was only $2200 shipped, but it sounds like it may be too expensive to swap everything else over.
then you didnt look in the right location.
however the 14015445 is the casting number, making it a late Mk IV block
i would skip the Gen V and go straight to the Gen VI myself.
thormx11
Would the accessories swap over to gen 6? I had found one with the oil pan, timing cover, and valve covers included but would need to swap the alt, p/s pump, mounts, etc.
yes.
as a side note, your 1997 boat should have had a gen 6 motor in it to begin with.
thormx11
I will look around for a while for different engines and see what will be cheapest/easiest way to get on the water come spring. I have found a complete ready to drop in used gen 4 (I believe) for about 3k. I'd like to find a gen 6 for a similar deal but that probably won't happen. I may go with the gen 4 to get me on the water quickly and maybe after a year or two I can add some more HP with bolt-ons.
You need to build a motor for HP. There is a limit to what you can "bolt on"
thormx11
I should have stated the boat I have too. It is a 1997 Maxum 2800 with a single 454 & bravo 3. I believe torque would be more important than HP for this wouldnt it? I am not worried about going very fast, but would like to be able to get on plane easily with a few people on board. I have seen cruisers around this size that will struggle to get on plane with more than a few people on board.
Also, I have heard of people putting a 383 in these boats in place of the 454 and it working better than the 454.
But on a side note, I came across a video of one of the hot rod shows taking a 454 from an 80s motorhome with 330 hp and 475 torque and using a top-end kit from jegs/summit and ending up with 560 hp and 535 torque. I know the numbers would probably vary a little bit going to a marine application, but that would still be more than plenty for my boat I think. And I dont think I would necessarily have to do it all at once, I could probably get an intake/carb one year and upgrade the heads another year.
But at this point I am still just weighing my options and trying to figure out the most cost efficient setup to go with.
You cant take a 330hp boat V8 and get 560hp without a supercharger unless you change crank, cam, pistons, heads and intake. You need to do some reading on cam overlap and reversion
You can take a 330hp gen 6 motor (oval port heads with 360-370hp at the crank), change cam, modify the carb and get 425hp at the crank (385 at prop)
You can take a 385 hp gen 6 motor (rectangular port heads) and change cam, port the heads and change pistons to get 500hp to 525hp at the crank
