Merc 7.5 - Wont run at low speed
kingkat
I have a Merc. 7.5 horse that i believe is a 1978. It will not stay running unless the throttle is opened way up. Also must always choke to get started. It seems to run fine if I can get it moving and leave the speed up. I had taken it to a shop for the problem , (They werent in bussiness long ) Was told they rebuilt the carb and fuel pump but still have the same problem. Any suggestions, Thank You
12Footer
Re: Merc 7.5 - Wont run at low speed
Welcome to iboats. Poor compression. Fuel pump runs on compression also, so even if it's like new, poor compression will not operate it.<br />If the compression checks good, remove the exaust port plate,and clean the carbon out.
