Hi I have a 1978 70hp merc outboard, I've rebuilt carbs, new tanks, fuels lines, primer bulb, de-carbed engine, checked compression, (135psi on all three cylinders) ,new plugs & have spark at all cyclinders, ajusted carbs more times than I can count.<br /><br />My reaccuring problem is it's hard starting cold and warm, When it is running in neutral it seems fine(sometimes) or at WOT it is also good, when I put in forward gear, it stalls immediatly or if I try to punch it a little to get going it bogs out and stalls.<br /><br />Perhaps I'm not ajusting carbs correctly? I don't know? any help would be appreciated!
<br /><br />Thanks,
