merc 850 compression question
04whitetb
on my merc 850 the compression is below 100 psi on each cyl. i just purchased it a week ago. does anybody know of a product i can squirt into the cyl's to loosen up the rings to get them to seal better to help raise the comp?thanks
Chris1956
Re: merc 850 compression question
If the compression numbers are within 10% of each other, the motor is fine. What were they exactly? BTW - how do you know your gauge is accurate?
