Hi all...
I have a 1973 Merc. 850 that I just put on my boat to replace the old 850
(1974) that lost compression on #4 cylinder, note, the old 850 although running on 3 cylinder had no fuel issues, as part of the maintenance the tank was cleaned, fuel lines on the boat, prime bulb, and fuel seperator were replaced at the start of 2010.
The replacement 850 runs fine at all RPM'S as long as I keep it primed with the prime bulb. I replaced the fuel pump with the one off of the origional motor and still had the same issue, so put a rebuild kit in the other fuel pump and still have the same problem, engine will run out of fuel if I do not keep it primed with the bulb.
I will bypass the line to the fuel pump and the coupler and see if that resolves the problem as that is all that is left that is not new.
P.S. 140 to 145 compression on all cylinders.
