Hi everyone, I just found this forum researching a problem I'm having with my 850.<br /><br />I have an early 70's 850 that I keep in great shape. This engine looks new and I change the gear oil every year and the impeller every two. Due to getting married and buying a new house, my boat has sat covered for two years. This moring, I put fresh gas in it and tried to start it. It fired up in about 20 seconds.
I had taken the cowl off the motor figuring it would be hard to start. While I let it sit there and run, I noticed water seeping out around the top sparkplug.<br /><br />The engine runs great, idles fine, and does not smoke. The water that leaks out is clear and clean. <br /><br />How big of a problem is this? I have to assume that a gasket somewhere has failed. In AZ, Marine shops won't work on an outboard this old so I would probably have to do the work myself. I am very mechanically inclined, but I have now idea where this leak would start.<br /><br />Can someone help me narrow down what causes this and how much trouble the repair would be?<br /><br />Thanks!
