Hi....<br />I just recently put back together this engine...And started her up last night...I used the tank off my 90...the engine ran fine...cept it doesnt want to idle...The 90... I use a 50:1 mix. is that wrong for a 9.8..and if it is..what would be the proper mix? and if the mix is Ok for it..could it be a dirty carb? mix settings? The engine didnt run for about 1 year and started up on the 3rd pull.<br /><br />Also..is there a special oil for the gearbox? is it a 90 weight? and about how much is needed in there...I know its not much...<br /><br />THX all
