Merc 9.9 dies at idle runs great with throttle open
Jmac870
Anyone have any issues with their motor dying at idle? My 2005 9.9 will start if I have the throttle open and if I keep giving it gas it runs great. If I let off the throttle for it to idle down it dies.
jimmbo
Multiple posts on same issue. This one, newer, just forgets to mention the carb is in pieces
Jmac870
The carb is actually back together which is why I posted this after the previous post. Carb clean did not help
Jmac870
if you could be so kind as to maybe inquire before you discourage people from responding to my posts I would appreciate it
jimmbo
You said the engine was dying in your first post, where you had the carb all apart. an hour later you posted this one. You should have just continued with your original post
Jmac870
Okay next time I will try to keep it to one post. Thanks again for your info on other post
