merc A1 shim question
sarantis
Looking from the top of the housing after having it painted i observed a shim bellow the lower bearing cup tha seems to be useless.Nothing attaches on it and if i pull it ,it can easily be moved.I warry it may be there by mistake .It's diameter is larger than those of bearinfg cup shims'.So what is going on.I "ll try to add a photo.
tommays
Re: merc A1 shim question
4 is and o-ring and 5 is a shim
YOU REALLy do not want to be mixing up or touching the shims :)
Tommays
sarantis
you didn't get me but thanks for the reply.the lower bearing cup is the 11.So the shim I m talking about would be the 12.But it's not at the botom of the bearing cup but lower,a litle higher than the upper seal..
sarantis
you didn't get me but thanks for the reply.the lower bearing cup is the 11.So the shim I m talking about would be the 12.But it's not at the botom of the bearing cup but lower,a litle higher than the upper seal..Is my photo attached?If not ,shouldn't i use the option "attach a file"?
Nope,........
Down in the Tech, Non-boating forum, Pinned at the Top, is a Thread about "How to post a picture"............
sarantis
Today i found out what was going on. When i was trying to drill the screws of water poket because i had 4 of the 4 screws with broken heads one of them passed to the other side pushing upwards the bearing cup!
