Merc Alpha 1 exhaust manifolds help needed
StevenT
I removed my manifolds from a merc 5.7 with cracked block. How do I test the manifolds? I'm concerned they might have freeze damage as well.
ENSIGN
Re: Merc Alpha 1 exhaust manifolds help needed
I've read of guys using acetone to detect leaks and do not trust this method.I don't have X-ray eyes.I take mine to a machine shop and have them vacuum and pressure tested to be sure there good.
Ayuh,... Block off all the Water passages, 'n add Air,... say 15 psi, 'n wait...
If it stays at 15 psi, no leak...
