So this is the end of the second season since I've had my boat. It's an 88 Marlin with the 4.3 Merc and Alpha 1 drive. It's been a great boat, etc..
I have no idea when the last time the drive was off so I decided to pull it and take a look around with the intention of storing it off the boat.
So after winterization, I popped the six nuts off after putting the shifter in forward. Then the fun began. After an extended wrestling match I was able to get the drive about 1.5 inches separated from the housing. It felt like it was hung up near the input shaft as the bottom of the drive seemed to be looser than the top.
So more wrestling ensued until I found the post about blocking the top of the drive with wood. First try with a little hydraulic help the drive popped right out.
The input shaft has some old grease on it. I have no idea when the last time the drive was removed. Is it possible that the input shaft was stuck that tight to either the coupler or gimbal bearing? The gimbal bearing felt really smooth and didn't pop out with the input shaft.
I'm just looking for reassurance that I didn't miss a step and break something...
Fingers crossed, thanks in advance...
