Re: Merc Black max 150 Lower unit steering "colom" loose
The piece that connects the motor mounting bracket to the engine via the motor mounts is called the swivel pin. In the past the were made from high carbon steel. That has now been replaced with stainless steel. The HCS version had a tendancy to rust out at the very and and the retaining snap ring would fall off. It's almost impossible to lose the lower mount but that rust would creep into the lower yoke and eventually make it very loose. There are no bearings in the swivel pin hole, there are nylon bushings that just slip into place and theres a wavy washer to keep the vertical slop in check. If you have 1/6" of play in one direction, mulitply that by 2 and you'll get the total slop which is a lot more than spec.
The cost of the swivel pin will shock you so you might want to try eBay for a good used HCS version. You can order all the washers and bushings through crowley marine's online parts store if you don't have an account at Merc. Last time I checked they were still available.
If, when you tear it down and find that the motor mounts are shot, theres a really nice option to change to solid mounts. Look around at some of the popular merc racing outboard sites to locate those.
