merc bravo2 tilt up/down question....
piratedude
My bravo 2 trim button only works if i press the up toggle. down toggle is dead. nothing...I cant lower my drive..any ideas??? it worked fine before i trailered the boat from florida to california last month. thanks for any clues...
rodbolt
Re: merc bravo2 tilt up/down question....
hello do you have a multi meter and the knowledge to do basic checks ?
rodbolt
ok<br /> at the trim pump there is 2 solinoids. one with a green wire and one with a blue. use the meter to see if the green 18 ga wire has 12v applied to it when the down button is depressed. if it does not check the 3 prong connector plug at the pump. if you have 12v on the harness side and not the pump side the connection in the plug may be bad. once you dissconnect that 3 prong plug your trim switch will have no power. with the harness side in your hand you will need to verify continuity, with the down switch depressed, from the green terminal to the red one.<br /> could be a failed solinoid or switch or the plug was jarred loose during transit.
Don S
Perhaps this will help. The picture came from the service manual that give detailed steps on checking the system.<br /> Order Manual Here <br /><br />
jimmythekid
do what don says, and then if all okay, tap LIGHTLY on the solenoids while a helper pushes the switch, if it comes to life, you have a bad solenoid and/or connection, however if it doesnt come to life this does not nesessarily mean the solenoid IS NOT bad
piratedude
thanks to all for the input...really helps...so if i jumper the red wire on the pump side of the harness to the other wires, the pump works and both solenoids work. makes high whine sound when one side is jumpered and a lower sounding whine when the other side is jumpered. the drive still doesnt move up or down. any more idea?
tommays
p<br />it sounds like you got the pump to run there is a coupling between the pump motor and the pump which can fail<br /><br />i think your at the point were you need a manual there are a series of steps to take to find the cause with out guessing<br /><br /> http://www.boatfix.com/merc/Bullet/95/95_06.pdf <br /><br />tommays
piratedude
what would the best manual be for a merc? a merc manual, cylmer, or other?
rodbolt
hello<br /> most the merc manuals work better and are more detailed with the trim pump.<br />good luck and keep posting
