I own two Mercurys of the same vinitage,one is a 8hp and the other is a 15hp.<br /><br />I had them both next to each other with the covers pulled off. The only difference in the two that I could find was the carb size. The carb on the 15hp was bigger. The blocks are the same and everything else is the same, they could be twins of it where not for the difference in carb size's.<br /><br />My question is this,<br />If I took the carb on the 8hp and replaced it with a carb ment for a 15hp could I get the motor to put out 15hp?
