Merc Classic 50
johnoman
I have a Merc Classic 50, 1973, serial #A738353, 45 HP. The water pump is gone & I can not drop the lower leg. I've tried prying. I have everything stripped off the engine. The drive shaft seems to be seized into the crank. Any suggestions??? Please help.<br /><br />Thanks<br />Ken
12Footer
Re: Merc Classic 50
Did you get the hex head bolt out? It is inside that hole on the top of the tailpiece.<br />They can get hung-up sometimes.Try 'starting it loose". Also,try to rock forward/reverse a few times to see if it will let go.
johnoman
Re: Merc Classic 50
do you mean the one that holds the corrosion fin on or the one under that? the cassing has split abuot 1/4" i even tried to hang it upside down and have tried to split at the engine, all i get is 1/4" and the drive shaft wont seperate from the engine i don't know what to do next.
RICKRICK1
Ensign
Re: Merc Classic 50
Sounds like someone greased the top of the shaft last time they replaced the impellar. When you had it upside down did you spray wd40 or kroil done the shaft and let it soak using its own weight to break it free? May need lots and take a couple of days, make sure to have something soft under it so you dont damage anything else.
johnoman
Re: Merc Classic 50
thanks I'm going to try that, I did spray WD40 down the shaft or tried to but only waited 12 hrs and sprayed once I'm going to hang it again and spray lots will let you know if it works thanks.
johnoman
Re: Merc Classic 50
