Merc Cruiser 255 wiring hub help
legoman67
Well, i am repowering my boat with afew 255hp merc 350ci' the only problem is the wiring is different, on my old engines all the wires off the engine go to a bus, that is color coded, but on these all i have is a big plug, its got numbers on it though, and what i need is a reference to which numbers are which things, then i should be able to figure the rest out.
if anyone can help me it would be greatly appreciated,
thanks
Re: Merc Cruiser 255 wiring hub help
Ayuh,...
Go back to where you got the motor,+ ask them for the other 1/2 of the cannon plug....
Then wire it to your buss....
Today, 09:32 PM
Hmmm,.. Same Time Haut,...... ;)
legoman67
i do have the other end, but its just cut wires.
its a 1974 engine, the electronics have all been replaced over time.
legoman67
can anyone help? i just need a port # to function chart.
legoman67
hmm
thanks for the manual.
today i went out and did it by hand, tested the continuity to all the plugs, then compared where they go to the engine in the boat and what goes where from its hub, and have pretty much peiced it all together!
