merc engine alignment
MATMAN29
Is it possable to adjust the engine alignment on a 99 4.3 merc without using a hoist on the front of engine.I have the alignment tool and I think my engine is out of alignment since the tool slides in very hard once it gets to the coupler.it will go in all the way but it is very stiff. Any advice?
Don S
Re: merc engine alignment
All you do is adjust the front motor mounts up or down. That's why they are adjustable.
The Adjusting Nut does the Lifting, or Lowering.........<br /><br />A Hoist would Really Screw things Up..........
achris
More fish than mountain goat
Make sure you move both sides the same amount each time. Do you know how to 'read' the marks on the tool to tell you which way to go?<br /><br />Chris.....
MATMAN29
What do you mean by read the marks on the tool?
Don S
Put grease on the alignment bar and push it into the coupler. There should be equal marks in the grease from the splines all the way around the A-Bar. If not look at the marks. The heaviest marks means it hitting the hardest on that side and the bottom will show lighter marks. Indicating the front of the engine needs to go down in order to get the marks equal.<br />Keeping the weight about equal keeps the marks from going port and starboard.<br />IF, you can't get it aligned, it may be because the rear rubber mounts are bad or the fiber washer and double lock washer are missing or bad.<br />You should also turn the engine 180° and make sure the alignment is still ok. If not, the coupler is probably bad, or a combination of bad coupler and bad rear mounts and...............<br /><br />Once you get this figgured out, let us know. We will get you started on V-Drive and Inboard shaft alignment...... :eek:
rodbolt
ohhhh noooo<br /> I will be installing a pair of 8.1s in a boat this week. the originals had 72 series clutches and the new ones are 63 series ZF down angles. a mounting and stringer and alignment nightmare.<br /> but on your 3.0 application DonS has ya on track. maybe I can hire someone for mine :) :)
