merc enrichner valve
Capt Hazlewood
I'm re-assembling an 87 merc, 90hp, 3cyl. Does anyone know where the enrichner valve is mounted on the powerhead? Any info would be helpful!<br /><br />Thanks
gw204
Re: merc enrichner valve
Most likely on the front of the powerhead next to one of the carbs. That's how my '85 150 is set up. That valve allows fuel to drain from the top carb bowl to the lower two carbs. It's actually the choke mechanism. I'll check my Clymer manual for you when I get home.
