walleyehed
- Jun 29, 2003
- 6,767
1983 Merc 70hp..I've owned this engine for 14 years and last weekend it threw a fit.<br />When leaving one spot, I opened the throttle and it just bogged down....didn't quit, just won't run above 1500RPM.<br />Hit the choke, it done nothing until I let the key back, then it had a very short rise and then fell back.<br />I've decarbed every year, new plugs every year, and nothing but fresh gas and quicksilver oil. I just put a new fuel pump diaphram in it, but I've put about 30 hours on it since then.<br />I tore both carbs down monday, found no trash or varnish-this boat gets used year-round and averages 75-100 hours a year. I kitted carbs anyway, cleaned all jets and orifaces, checked float level, replaced all fuel lines under the hood, check all coils-all fire a 1/2" gap, compression is about 125 on all 3, just put new plugs in when I put the fuel pump diaphram in.<br />Mounted everything back up, checked all linkages, and lake tested...still the same...Idles great but when slowly advancing throttle it will bog about 1500-1700RPM and won't go any higher. At one point while playing with the throttle, I pulled it back to about half and hit the choke....it took off like a wild man and went on up to 5600RPM quickly...I ran about 2 miles and slowed down again and tried to plane back out..no deal, just bogs...<br />I pulled plugs and the top looked perfect, middle was a light to medium tan, and the bottom was a definite light tan-too light (Lean) and very clean on the face of the UL76V.<br />This one has cleaned my clock, and maybe I have missed something??? This has been a trouble-free engine for alot of years, and nothing has changed in my maintenance practices..<br />I pulled the carbs again today and can't find anything wrong....I'm very thorough with this sort of thing, and it's got me licked....<br />If anyone has a clue, I'm all ears..
