Merc hard to start when engine is hot!
garya0416
95 Bravo II 454 - engine starts quickly on a cold start, runs fine but when engine is hot very tough to get started?
anesthes
Re: Merc hard to start when engine is hot!
is the choke stuck?
garya0416
Choke is not stuck it moves freely, Carb. is clean. Fuel comes out nozzles when throttled.<br /><br />Help
rwjacobs
Are you able to get it turned over well when hot?
hoot
loose connections to starter, weak battery, starter going bad, timing set high, alternator not charging. one or a combination.
garya0416
It turns over very well when hot. Just won't fire up. Batteries are strong.
