Merc I/O 140 water pump
ArmyPat
I have MerCruiser Stern Drive Serial number 4668934 should it have an oil seal in the top half of the water pump which would seal drive shaft to internials of water pump or not ? <br />My system has a heat exchanger. :confused:
Pst76
Re: Merc I/O 140 water pump
Check out this site that have a parts exploded view. Just look up your motor by yr and serial # give part#'s as well. dougrussell.com
ArmyPat
I have check a Seloc rebuild manual and it says "late model drive units do not have this oil seal in the pump body". The boat/leg/motor combo is about 1977 vintage. Question is will I get a better pumping action with seal ?
Originally posted by Army Pat:<br /> Question is will I get a better pumping action with seal ?
No.....
