Merc I/O side mount controls ?????
Grew 194
I have a Grew boat with single lever dual action side mount controls and I like to know if I can swap it out and put in dual lever single action side mount controls???? I like to have one lever to control throttle and one control for forward and reverse . can this be done? thanks for your time and what controls would be the best
Re: Merc I/O side mount controls ?????
Ayuh,.... Sure,... Go for it,....
Ya may, or may not need to replace the cables,....
Depends on the controller ya choose,... Gonna no doubt be custom/ aftermarket,...
thumpar
Why do you want to do that? I just personal preference? There should be a button for throttle only or you can pull out for throttle only depending. Those style controls are usually for bigger boats and diesels.
mike165
I have an Ultraflex in my Bayliner two controls, the same cables fitted fine,I,ll see if I can find a pix
mike165
Att pix of controls
JoLin
I'm curious about the reason for the change, too.
Howard Sterndrive
I did the swap on my first Grew 175. I used an ancient Brydon Boy 2 stick controller that was laying around. Might still be here. For me it was just personal preference.
Grew 194
The reason I want to go to twin lever single control is that I have more control with the boat when docking or putting on the trailer if I can keep at low idle and just shift forward and back
