I ran into a bit of trouble replacing my impeller on my 1999 225 HP Merc 2 stroke. I got the lower unit off and replaced the impeller kit OK but when I went to put the lower unit back on I wasn't able to get the shift shaft splines to line up. Is there some secret here? I started out with the engine in forward as most posts suggested. I even have a shop manual but it doesn't explain how to line everything back up. I can get the speed-o tube back through, the drive shaft lines up but the shift shaft won't line up. We've tried rotating the shift lever to get it to align but to no avail. In summary everything except the shift shaft lines up. What to do?
