Re: merc in gear
assuming it worked before impeller replacement,<br />sounds like the shifter spline didn't line up.<br />did you have any trouble getting the lower end <br />back on? I had this problem and ended up breaking<br />one of the tables for the shifter cam in the<br />bottom of the lower unit, then it wouldn't shift.<br />hope that's not your problem, it's cast into the<br />inside of the lower unit. luckily my local shop<br />was able to fabricate a piece to fix and I<br />didn't have to buy a new lower unit.
