Merc lower driveshaft needle brg
valmach
Hi, Can some one tell me whether the lower driveshaft brg is pressed in from the top or pulled up from the bottom? Is there a shoulder at one end or the other? JLM
merc850
We need the year/serial Nr. eg: a 1970's bearing is pressed into the cavity.
valmach
Hello, It's a 1979 Merc, 80hp, 4 cyl, 2 stroke, ser# 5480528. I need to know if the lower driveshaft needle brg is pressed in against a shoulder or a straight thru bore. I'll make a driver to remove and install.
merc850
This is what I have from the 75-78 manual, I don't think there's a shoulder anywhere at the bottom or top of the housing. Removal is easy; installation is trickier.
